Hello,
I would take a look at the source code of some audacity effects.
In particular:
1 - Change Tempo (without changing its pitch)
2 - Noise Reduction
3 - Equalization
4 - Compressor
5 - Spectral edit multi tool
Please, can you tell me the names of their source files ? That is where can i find their corresponding files in the source code ?
Another question: does exist the plug-in of an equalizer impelemented in real time ?
Thanks in advance.
Vincenzo.
2
The first 4 are in /src/effects
https://github.com/audacity/audacity/tree/master/src/effects
The Spectral edit effects are Nyquist plug-in scripts.
The plain text script file will be in your plug-ins folder
In the source code: https://github.com/audacity/audacity/tree/master/plug-ins
The plug-in code is parsed by /src/effects/nyquist/Nyquist.cpp (https://github.com/audacity/audacity/blob/master/src/effects/nyquist/Nyquist.cpp)
and is implemented by libnyquist (/lib-src/libnyquist)
3
