WIN 10
No sound on play back. I can play previous recordings, and I can record a new one but no sound when playing it.
Realtek USB Codec speakers functioning properly but not in Audacity?
Help would be appreciated
WIN 10
it is
Please post the âAudio Device Infoâ (See: https://manual.audacityteam.org/man/help_menu_diagnostics.html)
Make sure your USB is plugged in and turned on before starting audacity. Else, select Transport > Rescan.
Trying to. I went to your link clicked the OK button but canât find the report.
Which version of Audacity do you have (Look in âHelp menu > About Audacityâ)
2.1.2
Update Audacity to the current version (Audacity 2.4.2 https://www.audacityteam.org/download/windows/)
Use the âAudacity Windows Installerâ version.
During the installation, select the option to âReset Preferencesâ.
Updating and resetting Preferences may be sufficient to fix the problem, but if not then we can dig deeper.
downloaded 2.4.2 still no sound on playback
OK, so lets take a look at that âAudio Device Infoâ:
Hello Steve, you can forget about this issue. I can now record and play it back. I switched to another set of speakers and set them as the audio out device in Audacity. However I still have no sound otherwise? Any ideas? Windows Media Player problem maybe?
Thankâs again.
If you havenât already done so, try cycling through the Audio Host: MME, WIndows Direct Sound, Windows WASAPI. Perhaps one of these will work.
Why do you think this might be a WMP problem - Didnât you say âspeakers are functioning properlyâ?
