sound track effects
I’m new to Audacity and am having some difficulties with what is probably a simple issue. For instance, I recently began a podcast. I recorded 2-3 minutes, then highlighted the section and applied some effects (noise reduction, normalization, graphic EQ, compressor and again normalization) and it worked fine for THAT 3 minute section.
I then went ahead and recorded the rest of the program, another 23 mins … only to discover that the effects I had added earlier to the first 3 mins, were not automatically applied along the entire track. Aha, I thought … all I have to do is highlight the entire 23 min track and reapply those same effects … but that didn’t work.
So, the simple question is “how do I apply ‘effects’ across an entire track?” Do I do this at the beginning somehow , or at the end?
See my reply here: https://forum.audacityteam.org/t/workflow/56085/7
I am closing this topic to avoid cross-posting. Please use the other topic to continue this discussion.
