ive recorded a song, it sounds well in audacity but when I saved it and played it in my media player its sound much different, what do I do pls
What operating system are you using?
Which version of Audacity? (look in “Help > About Audacity”)
I am using a pc windows 10, and the version of the audacity I am using is 2.1.0
This is a little rough. It’s like “my shirt is the wrong blue.” There are too many ways to go.
What are you recording? Are you singing and playing the guitar into a microphone? Did you Export an MP3 sound file? Close everything, then open Audacity fresh and import that same MP3 sound file. Does it sound like the original good version, or like the bad version?
oh yes its now all good, thank you
“User error”?
It could help others to say how you fixed the problem.
well actually, I just re install audacity
That won’t be what fixed the problem, but I’m pleased the problem is fixed, whatever it was.
