Sound Interface Recording on Audacity
I have a BOMGE BMG-115 USB Audio Interface. I plug the USB into my laptop and the headphone port into my piano. I play and record but the audio ends up really fuzzy, the
the audio sounds like this:
Is there anything that I’m missing or how am I able to fix it with the things I already have?
Haven’t you asked the same question few days ago?
What does that mean? What “USB”? What “headphone port”? What sort of “piano”?
It sounds like you might be trying to plug the speaker output of your keyboard, into the microphone input of your laptop, which is unlikely to work without causing massive distortion (like your sound sample). If that is what you are doing, then you should stop doing it before it damages the mic input.
