I have a new HP Windows 11 computer. I have a new Tonor mic. I have Audacity 3.2.1
the mic pics up the sound from a violin very well. But I notice it has a slight wobble. Not sure if I can correct this.
A “wobble” in pitch, or in volume?
Either way it’s strange…
I
Could that be the natural sound from the violin?
I can’t think of any way to easily change this. Can you match sound with the tremolo effect?
Windows audio-enhancements can be on by default on a new computer.
If you want a faithful recording should switch them off …
https://youtu.be/eXGyAzk3fd4?t=50
[ Disable the recording & playback “enhancements” ].
