Sound Fading During Playback/Recording[SOLVED]
hi, when playing back recording, the playback fades to a “tinny” sound as if all the low end is removed, after a pause, playback returns to normal, (& sounds really good), then fades again, i’m on win7 w/ the latest release, using a peavey diamond pvm22 mic into pc via 1/4" to 3.5 mm adapter to mic input, thanks…
Ensure that the Windows Sound “Enhancements” are turned off: http://manual.audacityteam.org/o/man/faq_recording_troubleshooting.html#enhancements
thanks alot for the quick reply, i got it figured out after i did a search after i posted, all good now… :laughing:
