SOUND ACTIVATION DELAY
Hi,
I use the sound activation. it works good
but I need to add a delay after the sound is Below the activation level.
Otherwise I Get a sound cut. and voice is mixed one with the other
How I do it,
Thanks,
You could try setting the activation level a bit lower, but that is currently the only setting there is.
