Audacity crashes when sound activated recording is enabled and record button is pushed.
** (audacity:5660): WARNING **: Couldn't register with accessibility bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
ALSA lib pcm.c:2267:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2267:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2267:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:867:(find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4607
Expression 'alsa_snd_pcm_hw_params_set_format( pcm, hwParams, Pa2AlsaFormat( hostFormat ) )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1786
[xcb] Unknown request in queue while dequeuing
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
audacity: xcb_io.c:165: dequeue_pending_request: Assertion `!xcb_xlib_unknown_req_in_deq' failed.
Aborted
What are you trying to record?
My guess is that Audacity lost its connection to PulseAudio. Depending on what you are recording, there will be a way to bypass PulseAudio.
Recording works fine with sound activated disabled.
It is repeatable for me and another person running opensuse Leap 42.1.
** (audacity:17963): WARNING **: Couldn't register with accessibility bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
audacity: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.0.
Aborted
I have no idea if my wxWidgets uses STL. I don’t know how to check. I am using the version that is available in the opensuse Leap 42.1
After looking at everything that has wxwidgets in the name in the repository, I think this might be a little complicated for me. Hopefully Packman will update soon.
I am not using the opensuse Leap 42.1 package. I originally used it, and it crashed as described. I then switched to the latest version in the Packman Leap 42.1 repository. I believe the error messages were the same.
