Just used the Alpha 2 (Audacity-4.0.0.253031629.f3e3e3b.-x86_64) to edited a 10 minutes recording, here are some thoughts.
- It no longer auto plays when clicking on timeline top bar, which…I understand, but I want it as an option.
I constantly re-listen to grab a finer take, and the need for manually stop and play every time, adds up real fast. - When clicking on the item, the ever-so-slightly dragging makes it a tiny area selection, and then the playing gets cut really short.
I think it’d be reasonable to measure how long the user had been dragging the mouse, and set a threshold to determine if it’s intended to do an area selection. - The input meter preview is always on even when muted, which is just annoying. I prefer the Reaper way, which let me set if the track is active.
- The Track volume slider…It’s nice that holding shift gives finer control, but a manual number input would still be a lot better. Also, the tip that shows the current value never goes away, even stays on top when browsing other window. (Might be a KDE thing though.)
- When I select an area, do a ripple delete, realized it’s not quite right, so undo…The selection is off by one undo step. It’s now selecting the previous selection, and if I want the last selection, I Redo…and it also re-delete the wrong area.
- When doing ripple delete, for about 1 frame, the track is empty. It looks like nothing existed in that track for that split moment until it’s done processing.
- The Play button is inconsistent. Sometimes it just decided it wants to play from start, sometimes not, both UI button and space. I haven’t figure out a logic behind it.
That’s about it. Just in case, here’s my spec:
Operating System: Bazzite 43
KDE Plasma Version: 6.6.4
KDE Frameworks Version: 6.25.0
Qt Version: 6.10.3
Kernel Version: 6.17.7-ba29.fc43.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 5600X 6-Core Processor
Memory: 32 GiB of RAM (31.3 GiB usable)
Graphics Processor: NVIDIA GeForce RTX 3070 Ti
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: X570 GAMING X
