[SOLVED] ACX Check Is Stuck At Disabled
I click to enable, click OK, then try again and it’s not enabled. I’ve used it once already, but I am stumped as to why it would do this. Perhaps I reinstall it?
Suggestions?
Did you install ACX-Check by Tools > Nyquist Plugin Intaller?
There’s two ACX-Checks. You should be using the latest one. The legacy one will not check long passages.
https://wiki.audacityteam.org/wiki/Nyquist_Analyze_Plug-ins#ACX_Check
Are you reading for audiobooks? There are some tricks to it.
I installed the latest version and it’s working now. Of course, after I submitted this and before I see the responses! Thank you!
