Solo/Mute causes clicking sound
I have mutiple tracks. When I click mute on all but one track OR if I use solo to isolate a sinlge track, I get a load clicking sound on playback. This only effects one track. And it’s random. If I remove that one track, then it’ll happen on one of the remaining tracks. Regardless, there is always one track that I cannot listen to isolated without the clicking noise. It has no effect on the output audio file; just the playback during the editing process.
I’m using 3.4.1. I have tried with and without headphones, changing the Hz, etc. It doesn’t seem to be related to the type of audio. It seems to be related to the program.
If you can provide a link to a project that exhibits this behavior, PM me a link; I’ll take a look at it.
Thank you, but the problem seems to have resolved itself. I still do not know what the cause was. Nothing changed that I can tell. I hadn’t even done a reboot.
In each case this should be solved in 3.4.2
