Hey so I have a two person audio to edit. I use the stereo for recording channels but I add two separate mono tracks to record separately as that was the only way I could get it to record,edit, and export the audios. However when I do this the wave form is very small unless there is a loud noise like laughter then there will be a high waveform. What is the best way to increase the size of the waveform even with a few sections of having high peaks in waveform? hopefully this makes sense.
