slow sound to 75%
Can I set the sound such that all computer sound is slowed down to about 75%
Live computer sound? Audacity doesn’t do anything in real time.
Capture your work, put it on the timeline, apply the effect of your choice and listen to what you did.
See here for the speed changing effects in Audacity: http://manual.audacityteam.org/man/index_of_effects_generators_and_analyzers.html#Make_the_sound_faster.2C_slower.2C_lower_pitched_or_higher_pitched
There is a [u]Speed Control[/u] to change the speed in Audacity during playback.
Or, you can apply the Speed Change effect to a file and save (export) the modified audio file so it will play back slower on any application application/device.
In order to slow down all sounds in all applications, you have to “hack” the soundcard clock (hardware) or the driver (software). Not easy things to do and not practical things to do. Normally, the sound file (or stream), the application, the driver, and the hardware are all working together cooperatively, trying to play back at the correct speed.
