Slight echo/reverb in recording
Upgraded from a dynamic to a condenser mic, applied sound blankets to the walls and hung sheets from the ceiling to reduce echo and I still get a slight echo or reverb. I’ve attached a raw file. Any help would be appreciated. Thanks.
Sound Test.aup3 (804 KB)
The blankets for sound treatment have to be heavy, like a quilt/duvet/moving-blanket.
A sheet is not going to have a noticeable effect.
They are sound blankets designed to absorb sound. You can find them on Amazon, just look for sound blankets. Planning on trying an isolation shield. On the plus side, I noticed a huge difference with my old mic.
Dynamic mics are less sensitive than condenser mics.
If you want to reduce reverb in the recording, dynamic mic is better.
