Hi, I’m using audacity 2.3.2 and I’d like to know if there is a way (external plugin or something else) to get a changing Equalization over time.
I’d like to be able to change Equalization dynamically, that is to set a starting condition and an ending condition, and then get an audio which gradually change EQ.
There is a plugin which does this with tempo and pitch called Sliding Time Scale/Pitch Shift.
Is there a plugin which works like that but with EQ?
If you need to do this a lot of times, you could write a Macro to perform the steps (see: https://manual.audacityteam.org/man/macros.html) but note that you have to use “named curves” in the EQ effect.
I’m using autohotkey and it is very fast with it, here is is my code if somebody want to try
CapsLock::
send !c ; open the Effects dropdown list
sleep 200
send ee{Return} ; select Equalization
sleep 200
mousemove 170,460 ; move the mouse on the Select curve dropdown list
sleep 200
send {wheeldown} ; select the next curve in the list
Return
F2::
mousegetpos x,y ; save current mouse position
sleep 200
send !c
sleep 200
send f{Return} ; select Fade In
sleep 200
mousemove x,y ; go back to initial mouse position
Return
F3::
mousegetpos x,y
sleep 200
send !c
sleep 200
send ff{Return} ; select Fade Out
sleep 200
mousemove x,y
Return
