Audacity 2.4.2
Sometimes (not sure why “sometimes”) if I drag my mouse across a section of a track, then play, it skips the highlighted section, instead of playing it. What am I doing wrong?
Audacity 2.4.2
Do you use custom keyboard shortcuts? If not, try setting your shortcuts back to defaults (see: https://manual.audacityteam.org/man/keyboard_preferences.html)
The behaviour that you are describing sounds like “Play Cut Preview” which has the default keyboard shortcut “C”.
I don’t use keyboard shortcuts. Mostly use the mouse
