I mostly use VLC. I get my file size and format information from Windows. I don’t hide my extensions. Also, when I hover the mouse over the file, a little window opens, showing that same information.
If I have a flac file that sounds sort of flat, I use Audacity to enhance the file to suit my listening preferences due to some hearing loss.To help us determine why I’m getting large files, I put the file below in Audacity and made changes I might normally make.
General
Complete name : E:MusicBERT KAEMPFERTBaby Elephant Walk.flac
Format : FLAC
Format/Info : Free Lossless Audio Codec
File size : 15.2 MiB
Duration : 2mn 51s
Overall bit rate mode : Variable
Overall bit rate : 744 Kbps
Album : Bert Kaempfert And His Orchestra
Album/Performer : Bert Kaempfert / Bert Kaempfert
Track name : Baby Elephant Walk
Track name/Position : 14
Genre : Instrumental
Recorded date : 1978
Audio
Format : FLAC
Duration : 2mn 51s
Bit rate mode : Variable
Bit rate : 744 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 15.2 MiB (100%)
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
I increased the Bass by three decibles. I increased the treble by two decibles. It sounded better, but still flat. Using Compress Dynamics 1.2.6, I set the Compress ratio to 0.3 and Compression hardness to 0.3. I leave the Floor preset at -32.0. I leave the Noise gate falloff preset at 0.0. I leave the Maximum amplitude preset at 0.99. After compression, the file sounds much better.
The last thing I did, which often helps me hear instruments I didn’t hear before, is to offset the tracks. I split the stereo track. Then with the cursor set at 0.0000, I shift the start time of the left channel to 0.0010. I made no other changes and left Audacity preset to Project rate 44100 Hz (as a matter of fact, I have never changed this rate).
The file now sounds much better, so I export it, leaving it in flac format.
As you can see the file has more than doubled in size. Could any of the changes I made have caused this increase?
General
Complete name : C:UsersUserDesktopBaby Elephant Walk after Audacity.flac
Format : FLAC
File size : 30.8 MiB
Duration : 2mn 51s
Overall bit rate : 1 510 Kbps
Audio
Format : FLAC
Duration : 2mn 51s
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Stream size : 30.8 MiB (100%)
