Simultaneously generating a tone and recording a sound
Hello,
I would like to do the following:
  1. generate a continuous tone and output it via the headphone output of my soundcard — this is easy.
  2. input the tone to an electronic circuit — no problem
  3. record the output of that circuit, while the tone is being generated.
So, basically: can I use Audacity to simultaneously generate and output a tone, and also record another signal (via the same or another soundcard)? And, of course, if “yes”: how?
Thanks,
Fred
Windows 10
Audacity 2.2.3
Try Tutorial - Mixing a Narration With Background Music[u][/u] or [u]Tutorial - Recording Multi-track Overdubs[/u]
  1. record the output of that circuit, while the tone is being generated.
You can’t play a tone while it’s being generated with Audacity but you can play a tone that was previously generated.
