Simple Question
Hi Guys
First time I have ever used this software and all I want to do is create a separate 20 minute audio file from a 1 hour 30 minute audio file. I know the exact start point (29min 33sec) and finish point (50min) but I simply cant figure out how to save that section of the audio file as a seperate file ?
I know there will be a simple answer, but I’m obviously missing it :unamused: could somebody just give me a simple guide please bearing in mind I haven’t used this before :laughing:
Thanks
File → Export Selected Audio
You can also select the parts you want to delete and then hit the DEL key on your keyboard (or Edit → Delete.
