Not sure if this is in the newer Audacity (I use 1.2.6), but as a suggestion, you
definitely need a smarter silence adder.
For instance, you might have a 128 bpm track with each measure being 1.874807
seconds. What I do currently is use that amount to add silence to each track where
that track’s loops (or audio) aren’t supposed to play (this keeps the loops aligned
time-wise).
This works well, but sometimes I end up with, say 8 measures of silence needed
and I either have to figure out the math, or repeat add silence until I get the
track up to the point of adding the loop.
It’d be nice if there were some sort of calculator on the silence adder, say an
entry box for a multiple [1.874807] [1] then [1.874807] [8]
That would be wicked smart.
