Show [Selection Length] of selected audio
At the bottom of the Audacity screen, it shows the [Audio Position], and then the [Start and End of Selection].
Enhancement: Display in an added box, the [Selection Length].
Sometimes I mark the start and end of a selection of audio, and I want to know just how long that selection is; but trying to work it out from the numbers is just Hard Work!
It should be Quick and Easy to implement.
Many thanks.
Philip Tory
Technical Author, retired.
Gloucester UK
Click on the “Selection type chooser” and select one of the options that includes “length”.
See: https://manual.audacityteam.org/man/selection_toolbar.html#Selection_Position_Boxes
