Hello!
Is there a way to make a Keybinding or Macro to a Preference setting?
I would like to quit enable/disable the
" editing a clip can move other clip" setting.
If not I strongly hope that this feature will be avaliable in the next Audacity version
You can create a keyboard shortcut to a Macro in the same way as creating a shortcut to an effect. See: https://manual.audacityteam.org/man/keyboard_preferences.html
To create a keyboard shortcut to change a Preference setting, you need to create a Macro to change the preference setting, and then create a shortcut to that Macro. The Macro command is:
SetPreference: Name= Value= Reload=<0 or 1>
See: https://manual.audacityteam.org/man/scripting_reference.html
Thank you for reply!
I think the solution is not a Macro
but a Script.
Setting i want to toggle is
EditClipCanMove (as in audacity.cfg)
values can be 1 (yes) 0 (no)
I set the script “set preference” name: EditClipCanMove value=1 reload (checked)
But it does NOT change the preference! Any help?
Thank you!
Create one macro containing the command:
SetPreference:Name="GUI/EditClipCanMove" Value="1"
and another containing the command:
SetPreference:Name="GUI/EditClipCanMove" Value="0"
The first enables the option, the second disables the option.
I’ve just tested after setting "Ctrl + " to enable, and “Ctrl + /” to disable. It works perfectly.
Thank you again but it’s not working for me.
My steps are
- menu tools/macro/new macro/
- macro name " move clip"
- insert command scrolling all avaliable commands i find “set preference”
- preference name “GUI\EditClipCanMove” or also GUI\EditClipCanMove or also EditClipCanMove
- value 1
save-
I launch Macro “move clip” but clips don’t move. ( in fact in preferences “move clips …”. is still unchecked)
It must be a forward slash after “GUI” like this:
Oh yes!!! / and not \ !!! Works now!
Thank you so much for you help and patience!
