Short cuts for extra effect -
I’m a keen user of short cuts in audacity - like playing on a piano. I therefore wonder why it’s not possible (or is it?)to make short cuts for other effects than the classics in audacity. fx I very often use the delay from Steve Daulton, but I cant figure out how to make it up … can you help me, thanx
best, Soren
You should be able to do this. Most any Menu item can be made available as a short cut. See: Keyboard Preferences - Audacity Manual
Where are you having the difficulty?
