Hi,
I am in Audacity Version 2.1.2. I obtained through the website and the .exe installer.
I have decided because of certain other software I have which I need, to remain with Windows 7.
I have bought a Tevion USB Turntable BNIB off a friend. Its never been out of the box. A bargain at £24.99, (I hope!).
Obviously the software was a little out of date so I have downloaded and installed the latest versions of Audacity and LAME.
I am not brilliant with this technology but with the aid of YouTube I try to learn as I go along and I’m making progress. However I have come across a couple of stumbling blocks.
I have been following a couple of channels on YouTube, with one in particular that runs a series of tutorials, (Audio-Technica USA), covering subjects covering initial download of software, installation, setting up of Windows 7 and Audacity, recording and exporting to MP3. The whole 9 yards!
Problem is, the video, although not ancient by any means, is a bit out of date.
One particular set of settings I’m trying to figure out are for the Real Time Conversion (RTC) and the HQ Conversion (HQC) available from the Edit/Preferences/Quality menu. It seems that the terminology has changed in the drop down menus.
The video instructs to set the Real Time Conversion to “Fast Synch Interpolation” and the High Quality Conversion to “High Quality Synch Interpolation”.
The terminology in my drop down menus for these options is different and in both cases are as follows:
Low Quality (Fastest)
Medium Quality
High Quality
Best Quality (Slowest)
I’m not sure what to use and what is the equivalent of what is stated in the video.
Also, comparing different videos from different channels, there seems to be a difference of opinion regarding the setting of the Bit Rate for the Default Sample Format. Audio-Technica USA instruct the use of the 16 bit option. A different channel on YouTube instructs 32 bit. Not being an expert I need some guidance and further explanation please.
For the time being I have set up for 16 bit and used the default settings for RTC and HQC until I receive some clarification.
Experimenting with everything attached and connected, I am trying to record a vinyl album to my laptop. I am having problems with the input level. Even if I move the slider indicator down to 0.1/0.2, the wave seems very big, in fact it appears to be off the scale if I try to increase it any more than 0.2.
There seems to be no lea way to reduce but if I increase anywhere over 0.2, it is apparent that I cannot achieve the recommended 80% I have noted. All I seem to have is distortion.
Can anyone shed any light on this please? Am I doing something wrong?
I would appreciate any help forthcoming.
