Hello everyone
I wanted to ask if there is a way to set the half wave display setting as default.
It is not possible via a project and I have not found a setting.
It would be nice if the next version of Audacity had this option.
Greetings Tom
Hello everyone
Greetings Tom
I don’t believe there is a setting for that, sorry.
If you want to raise an enhancement request for that you would need to do so on Muse’s GitHub issues log:
You would need a GitHub account for that, but those are free.
Peter
Thanks for a quick reply, I’ll make an inquiry. I think this can be implemented quickly.
For information, the improvement request is available at Set Half Wave Viewing Mode as default · Issue #7261 · audacity/audacity · GitHub
Changing “Audcaity.cfg” does not work
That only changes the display of “collapsed” tracks.
would be interesting if you enter defaultmodechoicenew=HalfWave ??
it don´t work
waxcylinder’s reply is correct and should be the accepted answer.
