Seperate two audio tracks
I’m transcribing a conversation between two people, and one guy always interrupts the other so I can’t hear what the other guy is saying. Is it possible to seperate
the two conversations so I can pick up what the other guy is saying?
If they are both talking at the same time, no you can’t separate them. Of course, if it’s stereo with one person on the left and the other on the right, yes you can edit them separately.
If they are not talking at the same time, you can simply select/highlight the part you want to remove and it the Del key on your keyboard. Or, you can get a little more sophisticated and edit with short fade-ins, fade-outs, and cross fades instead of hard-cuts & hard-splices.
There is also an Envelope Tool that allows you to fade-down parts that are too loud or fade-up parts that are too quiet.
