Separating vocals from background music.
first post, i have an audio file of two women speaking while they have music playing on the background.
any luck trying to separate the audio of the radio from the womens voices
or to make the womens voices clearer?
I tried noise remover and amplify…
Can possibly pay someone to do this if you can make the words very clear…
file is 15-20 seconds long
Probably not.
Try the Equalization effect with the “Telephone” preset. Audacity Manual
That will reduce low frequencies and high frequencies that are below/above the main frequencies of the voices.
i will look into that thank you for the help
