I get strange echo noises when using noise reduction (filtering) on recorded speech and would like to attempt another method that I am not sure if it can be done currently in Audacity.
Instead of using the noise reduction feature or any other frequency filtering technique, I would simply like to select all the sounds with volume amplitude ranges (from + to - ) in a specified range and reduce their volume, without touching the sound peaks higher than the set limit.
I understand that the noise will then still be present where they coincide with the vocal sounds, which I can then attempt using noise reduction on, but then I might be able to get rid of the funny sounds that are evident in between words.
I am quite interested to hear what it would sound like.
The attached pictures attempts to explain what I mean.
Regards
