Selection.
Dear experts! Is there a hotkey “cut from cursor to end” or "cut from start (begining) to cursor? Without selection.
I don’t think so …
But you should be able to create a Macro that
  1. selects from cursor position to end (Shift + K)
  2. Edit > Cut (Ctrl + X)
and then you can create a custom keyboard shortcut for that Macro
Thank you, I’ll try. Happened!
:slight_smile: :sunglasses:
