selection will not highlight in front
I just opened my new version of audacity after recently switching to a mac. When I make a selection with the mouse it highlights behind the wave file rather than on top of it. I can’t tell what has been selected?
First I heard of this.
Do something on the screen to illustrate the problem and then perform a restricted screen capture.
Shift-Command-4 will let you draw a box around the area of interest and capture it to a picture file. If you want, you can also use Shift-Command-3 and capture the whole screen.
Post the picture on the forum.
https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
Also answer the questions in that pink band at the top of this message.
Note Audacity doesn’t directly support Yosemite (OS-X 10.10) yet…
