Selection Tool size
I have realised that the selection tool cursor is not editable. I changed my mouse cursor so it was much bigger but the selection tool…I cant make it bigger unless I can locate the image file within the software and change the file. Where is the file in audacity for the selection tool icon?
thankyou
I don’t think it’s in the Audacity code, but in the wxWidgets code, so you would need to customise wxWidgets, then rebuild Audacity using your custom wxWidgets. Some info about cursors in wxWidgets: wxWidgets: wxCursor Class Reference
