Selection points and labels
I am using Windows XP, installed from .exe installer
I recorded an LP to Audacity. When I exported it, I discovered in addition to labels for 8 songs, I had 7 other labels that were un-named. How do I get rid of the un-named labels so that I can import the files into iTunes in the correct sequence?
To remove labels without affecting other labels: Single-click in the text of an individual label, then press the DELETE or BACKSPACE key (as appropriate) on your keyboard until the text is removed. Once the label is empty of text, press DELETE or BACKSPACE once more to delete the label.
