I am working on editing a piece of music, and I can’t get the select to work anymore. I typically use the select pane and type in where I want to start and end, but that has stopped working. I’ve tried closing and reopening the file, but no luck. Click and drag has never worked because it will only define a looping section. What am I doing wrong?
So perhaps you hit F2 accidentally - this puts you into a funky Envelope Editing Mode. F1 will bail you out.
Other than that, I would try exiting Audacity and restarting. You can always save your project and reload it. (Can’t you?)
If you click&drag in the Timeline you will create a looping region
If you click&drag in the waveform you will make a selection.
Peter.
