Select and Delete Everything Else
I can’t think of a good tool or combination to do this. Drag-select a portion of the timeline > Delete everything else.
There is no Select > Invert-Select > Delete that I can find and there is no shortcut.
I understand I can Export Selected, but that’s overkill and smacks of desperation method.
Edit > Remove Special > Trim is close, but that’s not Delete. It leaves behind the show timing. I want Everything Else to vanish without a trace.
The Zero Time show is going to start at my selection, not the original show start.
  1. “Edit > Remove Special > Trim”
  2. “Tracks > Align Tracks > Start to Zero”
