I’m expanding what I know about Audacity, and I have a question.
I’m using Windows 10 and Audacity 2.4.2
I’m trying to select a section of a project to loop and use as a temporary practice track. I have Quick Play enabled and Enable Dragging Selection enabled. The selection will not scroll to the right of the screen. I can see it selecting from my start point to the right screen edge, then it stops and will go no further, it will not scroll to the right. And when I release the mouse button the selection plays from my start point to the point at the right edge of the window then stops. But if I deselect the Enable Dragging Selection feature it works. Why is that? I guess I’m confused about what Enable Dragging Selection does.
Thanks!
Steve
