Hi,
I recently changed from Windows XP to 7 as well as installed Audacity 2.0 and noticed that my recordings are experiencing significant pops and clicks. I use Audacity to digitise LPs. I also use a PC with a Lynx L22 card with the latest Lynx driver and firmware. This setup has beeen working well for years, before the recent change to W7, Audacity 2.0 , so I’m sure that one of these two (or combination of) may be the culprit. If it is a driver issue, is there a chance that this can be fixed? If not, are there any practical solutions?
Another observation, if it’s of any use: the sound is closer to scratching than single click/pop, and follows more closely the higher frequencies in the recording.
Thanks for any suggestions,
Dragan
