When I try and save a .aup file to Documents on my Macbook, I get something that says “Error saving file: The file is either unable to be saved or there isn’t enough space to save” I know that there is enough space, so I don’t know why it won’t save. Help?
Make sure you are saving to your own Documents folder and not someone else’s.
Entering a backslash “” in the file name of the project will fail. If you are using an old 1.2 version of Audacity, other characters in the name may fail too. Make sure you are using Audacity 2.0.5 from http://audacityteam.org/download/mac .
Unless you need a project, export to WAV or AIFF instead which are lossless.
If necessary, restart the computer then try saving a project again. Quit Finder if problems persist.
