Saving to wav - ulaw
Нi friends
I am using the 2.1.2 version.
When trying to export a file to wav - ulaw its saves the file to AIFF format file.
Thanks for your help.
Tsahi.
It’s a minor bug. I say “minor” because the actual format is OK, it’s just that the file name incorrectly has “.aiff” added.
I’m not on Windows, but I think you can get round the problem by entering the file name with “.wav” at the end when you export.
Hopefully this will be fixed in the next release.
Hi Steve ,
Thank you for your fast response.
Tsahi.
