saving removed vocals
Hi, I’m a newbie with a question I can’t resolve.
Is there a way to save what the Vocal Remover removes (ver2.0.5, WIN 7 installed from .zip file)?
the scenario is this: old wire recording (mono) both channels combined for fake stereo. The vocal remover successfully removed the speech and all that was left was the undesired background noise that I want to remove. Can I somehow recover what Vocal Remover took out and save that for a relatively noise free recording?
Thanks in Advance
You want Vocal Isolation.
http://manual.audacityteam.org/o/man/tutorial_vocal_removal_and_isolation.html
thanks? I didn’t know to say what I wanted to do. I’ll give it a go.
It’s hard to say if you’ll get satisfactory results. The vocal removal (or vocal/center isolation can be fun to play with but they rarely give you “professional” results.
There is a plug-in for Winamp called [u]DSP Centercut[/u] that can isolate or remove the center channel. (Winamp and the plug-in are FREE!)
[u]GoldWave[/u] ($60 USD after free trial) also has some advanced center-channel processing that can isolate the center.
As Winamp has changed ownership you’ll have a slight dance to find it: http://forums.winamp.com/showthread.php?t=374929 .
There is a bx_solo plug-in that does similar - see Vocal Removal Plug-ins - Audacity Wiki .
