Sample Data Export does not show up in tools menu
Hello to all,
I am trying to export sample data via the Sample Data Export plugin.
However, the plugin does not show up in the tools menu.
I need to export 256 samples so there is not a huge amount of data.
So far I tried the following:
I have uninstalled and reinstalled Audacity, resetting all the preferences.
I have checked if the plugin file is present in the source code path (C:\Program Files (x86)\Audacity\Plug-Ins) and it is in fact present.
I have tried disabling and enabling it and I have also tried removing the file from the directory.
Removing the file from the directory meant that I could not enable it in the Plug-in manager.
Has anyone had this issue or knows hot to fix this?
I’m using Audacity Version 2.3.3 on Windows 10.
Thanks for your help!
This is a screenshot of the Tools menu on my computer:
Double check that you are actually running Audacity 2.3.3. Look in “Help menu > About Audacity” to see the version number.
I was stumped by this for a while…
The manual says:
Accessed by: Tools > Sample Data Export…
However, In Audacity 2.4.2, it is not there. Only Sample Data Import is present on the Tools menu.
Some time later I happened to notice it was located on the Analyze menu!
For a fresh installation of Audacity the manual is correct.
However, “Sample Data Export” used to be in the Analyze menu, and if you have upgraded Audacity from a version where it was in the Analyze menu, then it will still be in the Analyze menu after upgrading.
This issue is logged on the Audacity bug tracker.
