Run with no gui
Is it possible to run the program without any gui? Like if i’m running the program on ubuntu server.
That would be really awesome. So you could just input a mic and then record without the gui present.
Then you could also start the program with ssh connection and record from a distance.
Best regards
Peter Storm
[Advert removed by moderator]
Audacity is not suitable for running on a server. It is heavily GUI oriented and it is not security hardened for server use.
SoX is a command line audio editor that may be more suitable: http://sox.sourceforge.net/
