Hi, this is on Audacity Portable which I’ve been using on various computers (and various versions of Windows).
I extracted the RoVee voice changer plugin and put it in my plugins folder, then added it through Effects>Add/remove effects> (selected it) > enable. But depending on which computer I used this program on, it either does not show up in the effects list at all (though says it’s enabled in the add/remove list) or it is in the effects list, does open, but does not operate properly:
You can input different setting numbers but it defaults to the same preset sound.
Thanks in advance for any bright ideas…
