RodeCaster Pro - Multichannel Input
The new RodeCaster Pro has the ability to present multi-channels that can be imported into GarageBand or Reaper64. In Audacity I’m only able to see the composite stereo connection. I’m not able to see inputs for the individual tracks. Is this something that could be added?
Thanks,
Dan
Audacity is only able to record from one “device” at a time. If the RodeCaster Pro appears in the macOS sound settings as a multi-channel device, then Audacity should be able to access all of the channels available for that device. If the RodeCaster Pro appears in the macOS sound settings as multiple stereo devices, then Audacity will only be able to record from one of those stereo devices.
Are you sure you have the latest firmware for your RodeCaster Pro?
With previous versions it supported only stereo output over USB.
