RMS plugin for Mac
Having difficulty installing the Wav Stats plugin. Mac user. I am able to drag the plug in into my Audacity and then Plugins folder but when I restart Audacity, WAV Stats still doesn’t show up.
What is the exact three-section version of Audacity (look in “Audacity > About Audacity”)
In other words, if you are using Audacity 2.1.1, click Analyze > Manage… then select and enable WaveStats.
If you are using 2.1.2rc1 for testing, “Manage” is called “Add / Remove Plug-ins”.
Are you doing something that another tool can do? If you’re analyzing an audiobook recording, there is ACX-Check which gives you the three audio specifications that ACX requires.
