I have the latest version installed and I have some old SANYO cartridge-tapes that play backwards. My reverse feature is not enabled so how do I enable it to use it?
If it’s not enabled, go to Effects → Plugin Manager and enable it.
Then make sure to select the audio (Select → All) before attempting to apply the effect.
Done what you said, and reverse is still not enabled.
Got it working. Thanks.
