Reverse effects used
Is there any simple way to reverse a track that has it’s pitch, speed, and tempo all altered? I’ve been trying to do it manually using the plot spectrum and ear but it’s far from perfect and taking really long.
Any help would be greatly appreciated. Thanks in advance.
your options are:
1 – start over with your backup original
2 – use ctrl-z repeatedly to undo what you did
3 – nope
<<<pitch, speed, and tempo all altered?>>>
It’s rough to affect all of those differently. How do you know the character of the damage?
Why/How has that happened?
(it could have a major influence on how to reverse it).
Tape problems ? … https://forum.audacityteam.org/t/cassette-warble/8223/2
