Hi, is there a way to retrieve selection/cursor position not only horizontally but also vertically? I mean, when I use “retrieve selection” in a different track other than the original track where I Stored the selection, the command doesn’t select the stored selection in the original track. Is there a way to create a new command for this maybe using Nyquist?
Thank you very much for your answer,
Juan Carlos
It’s possible with Nyquist, but not simple. The method would be much like this: https://forum.audacityteam.org/t/creating-new-commands-to-select-tracks/57737/2
Thank you so much, I’ll try to do it,
Thanks again,
Juan Carlos
