retrieve data from mini disc / probl enreg depuis mini disc
Hi
I can’t rec any sound from my mini disc. In fact, it even seems that no sound is processed by the software. How can retrieve my sound data from my mini disc ?
I use the last version of audacity 2.0.3, and windows 7
the mini disc is connected to the correct line entry ( the green plug )
The preferences are set like this :
host : MME Play : speaker ( Realtek High definition ) Rec : Line (realtek High definition ) Canals : 2
thank you very much for your help
Brownie
bonjour
Je n’arrive pas à enregistrer mon mini disc dans audacity. Le son ne semble pas même arriver dans le logiciel. Comment puis-je procéder pour récupérer le son de mon mini-disc ?
Je viens de télécharger le nouveau audacity 2.0.3, je suis sous windows 7
le mini disc est bien branché sur l’entrée ligne de ma carte mère ( prise verte )
La config est de l’interface est actuellement la suivante :
hôte : MME Lecture : Haut-parleurs ( Realtek High definition ) Enregictrement : Entrée ligne (realtek High definition ) Canaux : 2 (stéréo)
Merci pour votre aide
Brownie
The international standard is green for audio out, blue for line-in, pink for microphone in. So you may be connecting to the wrong computer jack.
Hi
thanks for your answer.
Sorry i made a mistake when i wrote my message. I actually meant blue. ( The green is the out line for the speakers i just had plugged again right before i wrote my message. Hence the switch in my mind between blue and green ! )
In the meanwhile I managed to get the sound of my mini disc. I still don’t really know why it works now…
I just find the level of the sound quite low… any tips to enchance the quality and level of the sound ?
Brownie
Turn up the input level on the Audacity Mixer Toolbar, or in the Recording tab of “Sound” in Windows (right-click over the line-in > Properties then choose the “Levels” tab).
If your computer has an S/PDIF input you will avoid loss of quality by connecting from digital out of your MiniDisc player to S/PDIF in of the computer using a coaxial or TOSLINK cable as specified in the player manual.
