I was wondering if there’s a way to make Audacity support high DPI displays such as the retina Macbook Pro (like using a fork build with high DPI support or changing it to use a system font)? All the text looks really jagged. I think it’s the only app I have that hasn’t been updated for modern displays.
We can’t support Retina until we update to a later version of the wxWidgets interface we use, and even then, Widgets support for Retina still has some problems.
You can try http://retinizer.mikelpr.com/ but you won’t then be able to change the Audacity export format from WAV.
